SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
- Joined
- Mar 8, 2017
- 1,751
Howdy All,
Been awhile since I posted anything. Been a busy last couple of months.
Got the splashwell from my welder and dry fitted into the boat. Took a couple times for my welder and I to get it to fit right. Didn't account for some slant in the floor or the transom. Nothing is ever perfectly square. LOL
Did final placement of the bilge pump and livewell pumps. Still have to wire it in, but everything has been placed
Here is a close up of the bilge pump. I decided to secure it via a blind rivet with Velcro. That will allow for easy adjustments and fixes in future
Hear is the splashwell with the livewell holes cut. I made the mistake of not cutting the holes first.... :facepalm: So I have a couple scratches that will need to be touched up.
Next steps will be to do final wiring in the bilge area before putting in the splashwell. Then the splashwell will be installed.
Also as a lesson learned, don't use the self adhesive to hold up multiple wires. After first falling off under weight, I secured it with JB Weld. That didn't hold either (Plastic pulled away from self adhesive that was glued with JB Weld). Going to add some velcro straps that are secured via blind rivets. Should have done that in the first place
Till Next Time
Till Next Time
