dhardest
Thread starter- Joined
- Mar 4, 2017
- 57
Hello all,
I just replaced the raw sea water pump on my 2007 Volvo Penta 5.0 GXI-G with a brand new (but aftermarket) pump. I meant and actually thought I bought an OEM pump on ebay, but when it came it was an off-brand but still brand new. Double-checked the ebay ad and sure enough it said "for Volvo Penta" in bold print but "aftermarket" in the fine print - so I just missed it). Anyway, I replaced the pump this weekend and all went well. Re-tightened the belt tensioner and put everything back together. Started engine, and water temp slowly increased to about 175 and held mostly steady. So, first question - is this about the right steady temp for this engine? I know the temp may run different when actually on the water and also when at higher RPMs when at speed and not running the water in off a garden hose, but was curious if this seemed about right. When I revved the engine to see if the temp would increase, it did go past the 175 mark a little but not much. It never went past about 180 and when I went back to idle the temp returned to 175.
The second question and the topic of this post, is that when I did rev the engine, I heard a squeaking noise that sounded possibly like bearings of some sort. I tried to listen close to see where in the engine it may be coming from (the new pump?, or other component that's run off the serpentine belt), but I couldn't tell for sure.
Could this be a result of over-tightening the serpentine belt using the tensioner? I felt the belt after tightening and it seemed to have about the same amount of play in the belt as before I disassembled everything (just going by memory). Is there a way to measure to make sure I have the right amount of tension? (I must say that re-tightening the belt tensioner seemed like an inexact science. On this engine, the tensioner loosens by moving to the right (when facing the front of the engine and looking at the belt). To move it to the right, I loosened the bolt on the front (by turning the bolt counterclockwise obviously) and then using the socket wrench to move it to the right, which if not done just so, would tighten the bolt again. So I had to sort of play with it to get the bolt loose enough to be able to move the tensioner but not accidentally tighten it again. Not sure of this makes any sense. Anyway - just saying that this may be an area where I may not have done it perfectly.
Any help or ideas would be appreciated - on both the running temp question as well as the possible source of the squeak.
