ib18
Thread starter- Joined
- Mar 2, 2013
- 489
I replaced my impeller 2 years ago. Johnson 90 hp went ok, but I did notice the shift gear was not smooth. So, finally decided to check it out. I found out that it would not lock into Forward or Reverse gear 100% of the times when I move the remote control handle on my boat. So, I disconnected the shift cable to isolate my problem. I could not move the shift lever into Reverse or Forward if the prop is not in the right position. ie. If I am not able to push the shift lever back to lock into Reverse or pull it forward to Forward, then I just kick/spin the prop and it will lock into Reverse or Forward.
Is my clutch dog in the lower unit going bad? or I need to readjust my shaft length again?
