Kauaiboy206
- Joined
- Mar 9, 2017
- 133
I guess time to read up on the manual, hopefully it's not too complicated. There's gear oil seeping through there somehow, but the trim works fine but I also have to install the trim sender/limit replacement. This boat did not come with a trim gauge, any reason why? How would the trim limit work if there's no gauge to go by?Yep, Reverse lock valve. The early Prestolite pump didn't have internal valving to stop fluid being forced in the opposite direction. The consequence was if there wasn't that valve (or it's out of adjustment), the drive would lift up in reverse gear. There is a full setup and adjustment procedure for it too, and it includes a reverse lockout switch, so the trim pump can't be run while the valve is closed (which 'dead-heads' the pump, never good)....
Chris..........
Kauaiboy206 said:but the trim works fine but I also have to install the trim sender/limit replacement. This boat did not come with a trim gauge, any reason why? How would the trim limit work if there's no gauge to go by?
Gear oil from the drive? That would indicte a leak at the yoke seal... Nothing to do with the trim system
Trim guage and trim limit are 2 completely separate systems. The limit is not set by the gauge, it uses a different switch. First question is, which senders does your boat have? If the senders are on the side of the gimbal ring you can order new senders, and they are moderately difficult to fit... A pain to gain access to the wire passage. If they are the older type, using a small hydraulic ram (mounted to the inner transom plate) to drive a linear rheostat for the gauge, sorry, NLA a long time ago....
Chris.......
You Operate it by feel or "ear". The gauge is an option on some systems. My neighbor has one without a gauge. Makes setting the trim less repeatable.
When it's out of the water I can hear a clicking noise when it's fully up or down, but when in the water it's harder to hear any noise from the pump because the boat is stripped at the moment and the engine noise drowns out everything. I've got a 79 sun runner cuddy 19ft and so far I haven't really driven it much 3x to be exact to get a real feel for it yet. Still on thr process of making sure it's mechanically good before really using it for my purposes. I did however hit about 30 yesterday on the wate with 3 adults and 3 kids on board, although at higher rpm the engine started to stress and getting higher temp around 185 or so so I let it sit at around 3500/3700 rpm crusing around 25.
... although at higher rpm the engine started to stress and getting higher temp around 185 or so so I let it sit at around 3500/3700 rpm crusing around 25.
GaryDoug said:By ear, I meant the sound of the engine speeding up or down and the propeller cavitation....
Apparently BoatUS has it wrong too in step 4:
http://www.boatus.com/magazine/2014/...ng-in-trim.asp
...This boat did not come with a trim gauge, any reason why?...
Possibly because a trim gauge may not be that useful.
I experimented with an analog trim gauge on my CC (yes, it's a Merc OB, NOT an outdrive like you have, but perhaps you would get a similar result). I found that the entire useable, "while underway" trim range was gauged within the bottom 1/16 or so of the needle sweep...the remaining 15/16 of the needle sweep was already into tilt territory. (And yes, my sender and wiring is all fine and reads correct sweep of ohms, that's just the way the gage reads)
It would be like if you had a 32gal tank, but your fuel gage measured only the top 2gal in the tank, and sat on "E" for the remaining 30gal. Not very useful.
(Now, if you're talking about digital / SmartCraft, maybe that could be "calibrated" and/or "truncated" into a useful trim readout. Or maybe a "high end" analog trim gauge would allow you to calibrate the sweep. Or maybe if you're an EE you could design a "resistance multiplier" circuit for your analog sender. But these are all things outside the scope of what I know about.)
As achris and GaryDoug are alluding to, you'll use trim (for one example) to prevent "porpoising" (i.e., trimmed out too far) or broaching / "nose-diving" (i.e., trimmed in too far) depending on the height and period of the chop you're cruising through, and that's a mostly "by feel" thing anyway--as in, you tippy-tap the trim switch a tiny little bit at a time, and when you go from either bow "plowing under" (or bow "bouncing around") to "rock steady," you're trimmed right. No gauge needed.
