Prop change,, or not
Crawfish Dundee
I purchased a used 50HP Evinrude that came from a pontoon boat. I am mounting it onto a 16 foot aluminum fishing boat. The prop size on this engine is 12.5 X 13. Thinking that pontoons are normally turtles, should I expect a similar ride, or will I need to change the prop for a little more speed?
Pontoons are displacement hulls. Your fishing boat is a planing hull. Youre going to need to change the prop
Crawfish Dundee
Ok, thank you for the lesson. I suspected I should change it, but needed to ask.
SeaDooSam
50 hp on an aluminum v hull? That thing should screw ic the boat is lightweight. Definitely need a different kind of prop.
Sea Rider
Tach current prop to see its wot rpm achieved as usually loaded. Compare to factory min.max wot rpm range, will know how far off that prop is. Go for a prop maximization from there for a less pitch...
Happy Boating
Crawfish Dundee
Yes, over rev I suspect.? I am thinking a 17 pitch is at the high end of the drive train specs for 50 hp. There is probably a recipe for the exact prop to match the hull someplace. Prop searches for Evinrude 50 hp 2 CY. give about 4 or 5 options of sizes, that narrows the choices.
Crawfish Dundee
Tach current prop
Happy Boating
I have no tac meter. I am rebuilding an empty hull, and didn't plan on having a tac or speedometer. I haven't a clue if the motor is wired through the pigtail for s tac.
Sea Rider
Won't match a exact prop for that hull as "weight" has not been taken into the least consideration. Need to test prop/hull/weight to dial best prop. For that need to buy a Hardline induction hour/tach model [FONT=&quot]HR-8062-2 Follow easy installation procedure. Check Iboats, Amazon[/FONT]
Once installed, go for a wot spin as usually loaded on flat calm, no wind water cond provided that OB has a starter prop to test. If so, check max wot rpm achieved and compare them to factory min-max wort rpm range, from that reading can go maximizing other prop to suit best your boating needs.
Happy Boating
