gstuck1956
- Joined
- Apr 25, 2015
- 5
I am chasing an overheating issue with my 2001XL Mercury 150 Saltwater 0T554697. Here is what has been done already?replace water pump (complete rebuild), replaced thermostats 2X, replaced poppet valve completely. Mercury suggested that I change my poppet valve to an 884236-split poppet that will open at a lower pressure and allow more cooling water. That part has yet to arrive to me so that has not been accomplished. I have the required PSI within the specs (idle 1-4 psi?8-10 psi at 3000 and 12-15 wot) for the engine (via pressure gauge check). Back it into the water and idle out to the point and temp on the gauge went to 180 real fast. Started to get on plane and the alarm went off. Back it down to idle and the alarm went silent. Gave it the gas and got on plane and no issue. Slowed down to go through the train bridge and the alarm went off again temperature gauge at 200. Allowed to idle to keep water flowing until alarm went silent and temperature gauge dropped back to 175. Started back up and the whole temperature thing started all over again. I am out of answers and out of money taking to the mechanic to help. I got close to 1500.00 in repairs in this catastrophe. I am also out of answers?except for the Filler block 67891 in the gear housing that I was told might be passing exhaust gas through?ANYONE GOT A SUGGESTION?PLEASE....Note pee is kinda week at idle but increases as the RPM'S go up.
