- Joined
- Jul 18, 2011
- 18,865
As follow up to my over heating thread from last year (an issue which seems to be resolved), I did discover the beginning stages of Bravoitis on my Port outdrive. So, I planned on doing the Bravoitis fix on both drives as a preemptive measure.
Fast-forward to now . . . the company that I work for is having some building renovation work done and they have asked that everyone 'work from home' over the next 2 weeks ( yea, right
). So, I have started in on the Bravoitis fix.
I know that with the engines out of the boat, the fix is pretty much a slam-dunk . . . but . . . the engines are too heavy for me to lift
, so I'm doing this with the engines in the boat.
I got the bell housings off . . .
. . . and have removed the inlet hose that leads to the sea water pump and also removed the hose fitting that attaches to the transom assembly. Of course during that process I dropped a 7/16" box wrench into the abyss on the starboard drive. I could see it still within the area of the transom assembly, but as I tried to reach it, it went further into no-mans land :facepalm: I may have to pull the gimball bearing out to get my hand in there to pull it out. If I don't get the wrench out, I'm sure with my luck it will find its way into the driveshaft coupler area and make a spectacular noise and associated destruction when least needed.
Anyway, I digress . . .
I have run into a bit of an issue that I'd like to get some collective wisdom and ideas on . . .
Since there is some Bravoitis already started, the insert removal tool (see below)
does not want to go into the now restricted fitting on the inside of the transom assembly (the insert at the bell housing was no problem) . . . I assume that it is the same insert in both ends of the tube :noidea: . The fact that access to that area is difficult with the engines in the way makes it even more difficult. but the standard plastic inserts now seem to be smaller than the tool needs, so it won't go in. the port side outdrive is a bit more severe and the plastic fitting is partially collapsed. The starboard side is intact although shrunken to the point where the tool won't fit.
I have these 'kits' from Mercruiser (quicksilver) to replace the standard hose installation.
I chose these kits versus the Hardin kit, because they are plastic in the critical area instead of stainless steel, which in my mind would just add to the root cause of Bravoitis (i.e. galvanic corrosion). I believe that AllDodge used this kit when he was referb'ing his boat a year or two ago.
Anyway, I am wondering since I am not able to remove the plastic inserts that would free up the hose from the inside, should I attempt to cut the hose from the outside and bore into the remainder of the hose to get hose and fitting out?
Not sure if anyone has direct experience or advice, but before I fully open the can of worms, I'd thought I'd float the question out there for comment.
Also, any additional advise (short of getting a new boat, as we have already discussed that ideas
) is welcome and appreciated.
T. I. A.
T. I. A.
