HVACRat
Thread starter- Joined
- Aug 6, 2009
- 31
This is a 1984 Empire hull with the afore mentioned motor. I have owned this boat for 4 years, the powerhead was rebuilt 6 years ago. I bought this boat from the second owner; the first owner was Texas Parks and Wildlife, it was a Game Warden boat. The VRO had been disabled before I bought the boat, I pre mix the fuel at 50:1 and it has never had anything but synthetic 2 stroke oil since the rebuild.
I have never had a second's worth of trouble out of this motor and it absolutely flies when working correctly.
Time before last when I had her out I had trouble with it running well at WOT, I found what I thought to be the problem; some pretty seriously degraded fuel lines. I replaced the fuel lines from the tank (midship) to the motor, including a new filter. Vent line seems to be fine.
However, when I had it out this weekend it was even worse; it didn't just not run well at WOT, but it didn't want to run at all (really boggs down) and would stall at WOT. It idles (not in gear) fine, or as fine as it always has anyway. The idle has always seemed a little rough to me, but it will idle for hours if I let it without popping, coughing or stalling. It starts fine, pump the bulb, prime the carbs, starts right up. Pumping the bulb when under way, at idle speed, does not seem to help either.
I've read a few things from Google searches, but wanted to tap the true brain trust and see what y'all had to say. From what I've read it sounds like I should replace all the fuel and vacuum lines under the cowling, rebuild the carburetors and change the spark plugs. I'm sure one of those is the cause, but I'm no mechanic.
What would you look for, what do you think is causing this and what do I need to do to get her back in shape.
