My trim gage began acting flakey and then went to the full UP position. I figured it was the trim indicator sender on the drive and sure enough, one of the wires was rotted off. I took the sensor apart and attached a new wire to it to get the gage on the dash working but would like to replace the senders. I know the Mercury procedure is to pull the drive and U-joint bellows in order to access the clamp bolt but I am wondering if the drive and hinge pins were removed, would there be enough clearance to R&R the clamp bolt on the harness wiring?
I found this old post: http://forums.iboats.com/forum/engi...easy-replacement-of-alpha-i-trim-limit-switch
But there is not room on my unit for a 1/4" extension to fit between the bell housing and gimbal ring.
Thanks!
Thanks!
