Minnkota PowerDrive V2 & a Minnkota MKA-16-03 Quick Release on a 04 Bayliner 195 BR.
Captain Thad
Starting a new thread to document my project.
roffey
Take lots of pictures, I'm thinking of doing the same for my boat.
gm280
Captain Thad, we absolutely love pictures on these forums. Post away and allow us to see what you are doing. I'm watching. :)
Captain Thad
No Title
Okay
Here we go!
The boat
The motor and mount.
Captain Thad
BlueNote2
It appears that the front of the mount (closest to waters edge will be bout 8 or 9 inches off CENTERLINE. I know you want it as close to CENTERLINE as possible. But... thats what I got.
This sound bout right to you? from your pics it looks CLOSE.
Captain Thad
No Title
Here I am mounting the motor MinnKota PowerDrive V2 to the top plate of the MinnKota MKA-16-03 Quick Release Bracket.
Removed the sides 2 Phillips heads. then bolted with 1/4-20 7/8" bolts 2 on each side.
Captain Thad
No Title
Couple of shots of the boat mounting site. the 6 foot level represents where I want to lay the PowerDrive V2 Motor.
BlueNote2
BlueNote2
@CaptainThad
Looking good... Your going to have to set it up the way you want to fish it.
Captain Thad
Yeah I just measured. Looks more like it might be bout 11" off center...that's just the way it's going to b.
I have it marked, looks like all my holes will be on that lower level (the navigation light being on the upper level).
I will use a baby bit and only drill one of the holes to make sure it's good.
I will drill the front hole (waters edge) nearest centerline first.
I did deploy the motor to ensure clearance.
Going to bed now.
gm280
Of course the ideal place to mount any trolling motor is so that when it is deployed, it is perfectly centered to the bow point. And that reason is so the trolling motor steers the same to the right and left. I've seen them mounted off centered from both sides and the owners don't seem to mind...I guess. But there are ways around any obstruction to allow it in the center.
However, with that stated, this is your boat and you need to be satisfied with it and no one else. JMHO
Captain Thad
No Title
Okay
I started.... I drilled the waters edge hole frurthest from the centerline...I put a bolt in and snugged it up to see where I sit.
The front needs to b raised 1-1/2" to get it level. If I drill the back hole put it in...then loosen the front that will bring it to level...anyone have any other idea?
I think I should shave the front spacer at an angle.
Captain Thad
BlueNote2
After looking @ yours up close. I see space on the waters edge side between your spacer and the mount. I'm wondering if I really need to angle it or I should just leave it. So what there's a space. It's only the aesthetics. Just need to be careful tighteneing them down. Can't tighten the front then back ...it will tear right thru.
Captain Thad
No Title
Here's a better pic.
Captain Thad
No Title
Okay both watersedge bolts are in. It's level both ways!
Captain Thad
No Title
Yo Adrian.........I DID IT!!!!!
gm280
If that setup works for you, great. But I would most certainly watch for it to rack over time or even break through the fiberglass when the long tubes are. You will surely hit things using the trolling motor and that will transmit the force to the mounting tubes. Watch for it.
Not that you have it mounted, you could even make a template of the area with some cardboard and build a solid fiberglass adapter to replace the bolt towers. Just a thought. JMHO
Captain Thad
gm280
Okay.. I did not show it but I have a 8x10 1/2 inch thick piece of ply-wood under the fiberglass with 1-1/2 inch fender washers under it.
Is this along the lines of your thinking?
Captain Thad.
Captain Thad
No Title
Here's a pic of what's underneath!
briangcc
I think he's referring top side. Those spacers are basically "floating" in space if you will. Any shock is going to be transmitted from your baseplate, to those spacers, and then down. Over time, it's going to "wallow" the holes in the hull and the backing plate and could eventually rack everything.
To prevent that from happening you could fab up a top "cap" that would house those spacers and provide a more solid mount for everything to attach to. Once you do that you will need to replace your bow navigation light as it will be blocked by your mount.
Think of it this way...what is more secure? Attaching those bolts to a 3/4" piece of ply and using spacers OR running those bolts through a solid 4x4 post? Going to take a lot more to wallow out the solid mount.
But as mentioned previously it's your decision as its your boat.
Captain Thad
Briangcc
I see what you are saying. so how bout just adding piece off 1/2" plastic (nylon) plate under the spacers. Essentially making a sandwich.... starting at the bottom you have the plywood then the fiberglass hull then the plastic/nylon plate then the spacers then the MinnKota bracket.
