Found me a basterd engine.
Workin on my 76 evinrude 135. PH has internal damage and I bought a "135" cheap with shot gearcase, however on closer onspection one of the water tubes is damaged and will not seal with the pump. Also the powerhead is obviously a newer 140 or 115 bubbleback but it?s been intalled on the single thermostat midsection with one of the long hex bolt on each side left out. Pulled the heads and the engine PH looks both out and in to be in great shape.
So my question is can I run it like this on the other midsection or what?s the problem? I understand that I will miss two bolts but will something else be out of line enough to restrict water/exhaust flow internally?
Can i machine the missing holes in the newer block and install the missing bolts?
The motor seams to have been run with until something in the gearcase gave up.
