Engine idles fine out of water, can switch gears to forward and reverse and prop spins. Whenever I put it in the water though boat will go into reverse but prop doesn't spin for some reason when it does on land?? When put into forward in the water it bogs down and shuts off almost immediately. https://www.youtube.com/watch?v=hbRgRnV5I58 there is the video from it idling in the water today. Timing was set by arrow on distributor cap pointing to the center of crankshaft, carbs have been cleaned and rebuilt and linked and synced, fuel pump has been rebuilt. I just don't understand i've tried adjusting the idle mix screw nothing really changed its sitting about 1 3/4 turned out and I'm at a loss of what to do.
