CaptnKingfisher
- Joined
- May 14, 2017
- 269
Picked up this old V4 for $300 cuz I had the same motor on the back of my boat (my other is a 1975, but most of the parts are the same). Old owner said it had no spark but ran when he put it away a decade ago (take that with a grain of salt, as usual). Compression was good, couple hundred bucks, I bought it. Fast forward to today:
I've got weak spark on Port side (cylinders 2 and 4) with plugs in. I can start and run the motor on muffs, but in the water when I drop to from (START- fast idle) to low idle to shift into gear, she stalls. If i throw it into gear and with some ether I can run for a minute before it quits. Presumable because the old lady is trying to run on 2 instead of 4. She's trying, but she needs help. So I got a DVA meter and tried a couple things. Here's what I found:
With the spark plugs out: Strong spark on all 4 cylinders. DVA tests according to spec. Things look perfect.
With the plugs in: Spark (on 2 and 4) will not jump 7/16's gap. DVA tests on orange coil wires are out of whack on port side of motor (the two that dont spark or spark weak)
I've swapped coils around and it doesnt matter, coils are good (brand new tested and work independently), plugs are good (also new), I've tried swapping the stator with the one from my other motor, same issue, I've swapped power packs, no change, same issue. So I'm really scratching my head here. Is this maybe not ignition system related at all? Maybe its a lack of RPMs with plugs in? I don't have a tach hooked up either though I've got one laying around from an old boat. I've done some hunting and pulled all the grounds and cleaned em and made sure theyre good. Battery is strong and tests well. I've got the manual but when I run through the manual diagnostics I arrive at Bad Powerpack or Bad Stator, but Ive tried swapping with my spares and dont see a change. Any advice is welcome, thanks guys
