chartersj
Thread starter- Joined
- May 14, 2013
- 300
My buddy just changed out a worn out 454 with a older 454 which was rebuilt, at least this is what he was told when he bought the motor. After getting it in the boat and fired up we notice a tick coming from the starboard side. We pulled the valve cover, and started it up and you could tell which one was making the noise. So we tightened it up just until the ticking stopped then the motor started running very rough and quit. It eventually started back up with enough throttle but then the rocker arm was very loose and even rattling around. We pulled the push rod and it was bent. The procedure says to tighten a half to 3/4 turn even after the tick stops. So i'm wondering how we could of ended up bending the rod? A little research looks like either a collapsed lifter or sticking valve?
