- Joined
- Jul 18, 2011
- 18,725
During the prep of my twin Mercruiser 7.4 LX MPI engines (serial #'s in my sig) the starboard engine started idling very high, like in the 1200-1500 RPM range, even though the throttle was closed. A week ago, when I first started the engines after the winter lay-up it ran fine. Today, not so much.
I figured maybe it was the IAC failing, so I checked all the sensor connections and replaced the IAC, since I had one on-hand. No difference. Occaissional the engine will idle down to about 900, but then it drifts back up to 1200 and even high, all by itself.
Anyway, I have the Diacom software, but forgot to bring my Windoze computer. So, I loaded the software to another computer and ran some tests.
Looks like it is the MAP sensor that is bad . . . Starboard Engine.
I also ran the Port engine for comparison . . . looks OK.
I did not run the port engine all the way up to temperature, but after about 10 minutes, it looked OK.
anyway, although I got an error code for the MAP sensor, the values that it was sending the Diacom software seemed to be similar to the Port engine, which was OK, no codes, etc. Just sort of curious what exactly signals the malfunction to the MEFI ??? (MEFI1 BTW)
Also, I think these MAP sensors are a bit pricey, IIRC, as a Mercruiser part ($100 + ). Wonder if there is an automotive equivalent :noidea:
