shaw520
Thread starter- Joined
- Aug 27, 2009
- 634
You know I started to do that and it seems there are soo many different variations of actuators. You wouldnt happen to have a link ??That actuator is covered really well in the Mercruiser manual for that model outdrive.
that is from the drive manual? I believe it is used in the Corvette too http://tech.corvettecentral.com/2012/03/1963-82-corvette-power-steering-service/
You got that right!. I would take my chance with a $99 ebay purchase first. I also have one sitting in my 92 Winner that might work, but as Jolin has pointed out, these units are tucked in there pretty tight, and a bear to swap out, may be easier to service in place.Way more than it should cost.
Yes Jolin,..still chasing the same leak. Its def not coming from one of the hi/low lines, ive checked thoughly. It is definatly coming from the rubber boot on the ball stud, and you are correct in saying that theres not supposed to be fluid there, but looking at the schematics linked above there's a seal between the pressure side and the ball stud. Im going to try and tighten the adjuster nut at the end ( under the dust cover), but the may end up throwing the balance adjutment off.
