I need some help/confirmation with the trim button on the std throttle controller. Calling several dealers in my area, they have no idea what I'm talking about.
I have a 2016 boat with the 4.5L, Alpha drive power package. First thing I notice is the 2 stage trim button does not work the same as previous years.. The button still feels like it has 2 positions, but only works as one. That used to be a great tool to monitor the trim height and how much rpm to use.
In my 2016 Merc manual for the 4.5L it states while using stage 2 (trailer mode) to keep rpm under 1200. Well that's pretty tough to do without this limit switch. So after a few hours of surfing the net, I came across this Mercruiser factory Rigging guide. It has a paragraph that reads.........
The Trim & Trailer functions on the mechanical remote control have been merged on the 4.5L. The ?Trailer? stage of the trim switch on
the MerCruiser mechanical control has no function. Above 3000 RPM, the 4.5L will trim when the trim switch is pressed until the drive
reaches the calibrated limit. Under 3000 RPM, the drive will continue to trim until it reaches the trailer limit or physical trim stop
So according to that statement, my trim is working perfectly fine. That means when loading the boat with the drive in the full up position, it's ok to run up to 2900 rpm's, even though u-joints don't like it.... Plus that is totally different than what the manual states. Would be nice if they updated their data.
Can any of you 4.5L users confirm how your boat works?
And if that is the end result, what is a safe trim height before I need to watch my rpm's?? I'll make a mental note on my trim gauge.
