domwebhost
Thread starter- Joined
- Jul 13, 2008
- 117
Hi all,
I have been reading MANY MANY posts on several different forums about the type of plywood to use, the effects of pressure treated wood on aluminum, and using epoxies to seal the wood. I am still a little bit confused and so I thought that I would ask it on this forum.
So, I get it that Marine grade is the norm and (CCA) (Around here in Indiana / Michigan area it looks like over $100 a sheet (if I am lucky) and I need to do a complete redeck).
However, I have read others that have said that they have used untreated (so as not to corrode the aluminum) CDX since the glue is exterior-friendly and have tried using various sealing/topical solutions to extend the life of the wood.
My questions are:
Could 3/4" CDX untreated be used and then coated with fiberglass resin (such as Bondo Fiberglass resin) on all 6 sides (including pouring/injecting into any voids seen at the edge) to make it water resistant and last considerably longer? (Is this even a thing that people do?)
Should I use slightly thinner plywood and build up both sides with coats of resin to make it 3/4"?
Would it need multiple coats?
Is it a complete waste of time?
Saturate all seams and screw holes with silicone (RTV) to further impede rot..etc?
Will carpet adhesive stick to fiberglass resin (I assume I would have to scuff it?)
If I had the $$$ I would get the best of the best marine grade plywood and do it like the big boys do, but my budget doesn't allow for it; however, I do have time on my hands and can score a decent amount of resin, so I am looking at this solution but I don't wanna throw my $$ down the crapper if it is going to fall apart in 2 seasons and may look into some alternative decking solution.
It is okay to laugh at my idea as I have thick skin and can take a joke
Happy Boating
My questions are:
Happy Boating
