100% drive oil, its blue.
Anyone have a quick manual to handle the reseal? I picked up the seal kit today
Here's the quick manual.
Drain oil.
Spilt drive.
Remove front cover nut.
Remove yoke and bearing pack (don't lose the shims).
Remove top cover screws and top cover.
Remove upper drive shaft and driven gear.
Replace lower seals.
Disassemble yoke and bearing pack.
Replace seal and o ring.
Reassemble and set rolling torque.
Drop upper drive shaft and driven gear back in.
Refit shims to front of housing and refit yoke and bearing pack. Hand tighten front cover.
Fit new o ring to top cover and fit top cover. Torque screws to 20ft-lb.
Torque front cover to 200ft-lb.
Check for slight clearance between drive and driven gears.
Refit top housing to lower housing.
Pressure test (@3psi and 15psi), making sure to rotate shafts while under both pressures.
Fill with oil, refit drive to boat.
Chris. ...
