Great videos, best trilogy ive watched in a while.
What i was contemplating was if the outlet of the oil chamber where the reset piston is located is blocked then oil wouldnt get to the mixing fuel area and the alarm wouldnt sound as the oil pressure would still be high from the main piston still pressurising the oil chambers.
I don't think that if the lower half of the oil reset pin's piston is blocked that the alarm wouldn't sound, I think it WOULD sound as there would be nothing pushing up on the end of the pin.
I will say that the check valve for oil INTO the mixing area is super tiny....the oil has to be clean and free of debris.....I could see a piece of dirt keeping the check valve open...I would suspect that the reset pin would STILL work if that were the case, BUT you might not get a full draw of oil into the oil chamber as you'd be sucking from both the bottom flapper valve for the oil and from the top check valve which would be a fuel/oil mixture. The flapper valve is a much larger area to draw oil in.
And what i was wondering about the spring (bear with me) was that when the oil reset piston goes up and hits the counter reset lever then something must be pushing that lever back down so that it can then be hit by the reset piston when it comes back up again, if that thing that does that (which i assume is a spring) failed then it would seem the alarm wouldnt go on as the lever would drop on the electronic end and so be in a constant activated (resetting state). Since you say thats a sealed unit then i guess theres no way that the kits provide a replacement spring for whats under there)
And struth what a conincidence regarding your tach failing. That confirms the no tach no horn theory!
Ahh yes that is possible, highly improbable that something would clog the upper portion of the oil rest pin's piston (above the pin actually) preventing the pin to come back up to its normal position, thus in a state of constant reset.
From observations there are two things that prevent the pin in being in a constant state of reset.
1 - the o-ring around the pin centers the pin in the orifice
2 - and most importantly the cradle that the pin rests on, on the electronic side is spring loaded, pushing back up the pin on the side of the electronics.
now if that spring rusts away from under the cradle, then that would be bad.
the oil piston does have some sort of seal, but it is not a normal o-ring, and not replaceable ( some teflon type of seal to ride in the bore).....indeed it is a pretty tight fit in the bore...the bore is metal and I can see how the bore could be worn away a teeny tiny bit .005" or more to no longer seal the gas on the backside of the piston. This would allow a tiny bit of gas to be pushed to the oil chamber (after drawing in oil in to the oil chamber) and force mixing a teeny tiny bit of gas with the oil in the chamber, up to the secondary check valve which allows oil in the fuel mixing area as well as push up on the oil reset pin's piston.
I wonder if OMC thought of that and didn't think was a big deal or expected that from the get go...
I love engineering.
Off to re-do the regulator to stop it from leaking water from below it and re-do the no-oil test....keep you posted..
