just_james
Thread starter- Joined
- Nov 9, 2016
- 57
Just took boat out to do final adjustments and for some reason idle seems erratic. Here's the history behind this motor. Got it in 14 and did normal maintenance since history wasn't known. Did run for summer. Then I parked it till this year. This year I put new Seastar remote on it and cables adjustments per OWN manual. Carb rebuilt down to removing welch plug from carb body to clean idle circuit. Fuel pump rebuilt and complete water pump assembly installed. Did a decarb running Sea Foam thru carb the let sit over night. Compress on top cylinder is 95 dry,108 wet with oil,
lower is 97 dry, 110 wet. Top cylinder spark will jump 1/4-5/16 gap , bottom jumps 1/2". I did notice that idle in gear seems like vacuum for fuel pump isn't pulling enough fuel. If I pull plug wires off one at time engine stumbles.
