Ignition control module
Stingray1961
805361t6
Does any one know if some one bedside mercruiser make on 1993 4.3
I know of no one which makes them anymore. There are still some that can be found but they are high. Can convert to Delco EST for a bit less
Bayou Dave
Not sure if it is marine acceptable, but have you tried an auto parts store?
Stingray1961
No Title
All the kits I see I don't see a module
Stingray1961
Ok dumb question the module is in the dist any one with exp with these how to set timing total
Ayuh,...... '93,.... This is a T-Bolt IV ignition, Right,..??
If so, just hook up the timin' light, check, then set the timin' by turnin' the distributor,....
If your talking about how to set the timing of the Delco EST, you use the provided timing pigtail and ground the one lead. After timing is set, the pigtail connector is removed the other connector which goes to the shift interrupter is reinstalled
Stingray1961
Yes I'm talking about the delco I'm not paying 300 for old ignition module when I can buy the whole delco set up for the same price I know how to set intial timing but the old thunder bolt was a v6 -14 so my initial was 8 plus the 14 on the module which gave total of 22 I'm not sure how the delco one works there closed can't ask them
