Bakeys
Thread starter- Joined
- Jun 14, 2012
- 63
Glastron G1700
Mercury 3.0
Alpha One Gen II w/ new 140? thermostat.
Cayuga Lake, NY
This one even has my local marina boys stumped.
Had the boat out a few times this summer. I can go for miles with the boat at a comfortable cruise speed of 3,000 to 3,500 RPMS. The temp gauge will maintain a steady 140?. If you watch the gauge very closely you can see the needle swing ever-so-slightly as the thermostat does it's job. With no change in the boat operation, the temp will suddenly climb. It'll climb until you throttle down to about 1,500rpms. Then the temp will return to it's 140? mark.
I have an impeller kit, so yesterday I pulled her out of the lake and proceeded to open her up. What I found was peculiar, to say the least. Basically everything above the metal impeller housing had experienced a meltdown. The plastic water feed tube was nearly unidentifiable. If it wasn't for a lighter brownish color, I wouldn't have known what it was. The plastic fitting that attaches to the housing for the water feed tube was partially melted. The exhaust flap had melted down and resembled a gnarled shoe heel, the stainless plate that once was affixed to the flap fell out when I separated the top and bottom drive halves.
The impeller was in beautiful shape. (The marina guy asked me if it was new.)
After examining the top and bottom halves for any more melted material, I replaced the melted components, ( not the exhaust flapper), reassembled the drive, and refilled with Merc gear lube.
Took it down to the launch and spent maybe ten minutes checking everything out with full throttle, 3/4 throttle, etc. Temp maintained a constant 140?. Everything seemed to be back to "normal". By the way, the thermostat was new last week in the event that the problem was that simple. Put the boat back on the hoist.
A few hours later I have my wife and folks in the boat for a ride down the lake. Temp remained at 140?. Seven miles down the lake, I watched the temp walk up and up. At 175? I throttled back and sure enough it cooled back down to 140. Nursed the boat home with 1/4 and 1/2 throttle and put it back on the hoist where she sits now.
So what did I miss?
This may be worth noting as well. When the temp starts to climb, the exhaust sound changes. There's a bit of a louder, low pitched rumble (for lack of a better word). So even if you're not watching the gauge, it'll let you know something is amiss. After it returns to 140, the exhaust rumble returns to normal.
Also, and this is when things seemed to change. Couple weeks ago I had the boat on the hoist and was running the engine to blow the floating weeds away from the shoreline. The outdrive was immersed but the weight of the boat was on the hoist. Ran the engine probably in the 1,500 - 2,000 rpms range for 15 - 20 minutes. It was after this that the problem started.
Thanks all for the anticipated insight.
Mercury 3.0
Cayuga Lake, NY
So what did I miss?
