- Joined
- Mar 8, 2009
- 44,427
We have a mix bag of info for pressure testing outdrives. The links below have different info and pressures/vacuum. Suggesting to bring things together with just one and on set of pressure and/or vacuum
This is in Adults only top section
http://forums.iboats.com/forum/engi...drives/239516-drive-pressure-check-prior-post
This link mentions 15 psi and use vacuum but does not list in Hg
A sub link inside it list 10 psi for an hour
This is inside the Mercruiser area
http://forums.iboats.com/forum/engi...ves/537689-od-presure-test?t=524743&p=5509236
This link shows 7-10 psi for 5 minutes
Then further discussions list 10-15 psi and then lower pressure at 3-4 psi, then vacuum test at 6 in Hg
achris Bondo ziggy Bt Doctur FreeBeeTony
