scout-j-m
Thread starter- Joined
- Jul 31, 2009
- 643
Aside from the design, is the performance of the later model 9.9/15 hp OMC carburetor identical to the earlier models which are all metal? I have a 1992 9.9 Johnson which has a 15hp carb of the same year on it....when I got the motor it ran great but never idled well. Found out it had 1993 or newer plastic top on it and had been rigged up so that it functioned like the 1992 model one by being able to work the low speed mixture needle through the front of the cowling. I replaced it with the appropriate year plastic top along with a new needle. It idles down better but is still doesn't get as low and smooth as I would like. Maybe it just needs a good cleaning.
But to the point of the post, I also have a 1982 15hp Evinrude which idles down great and I was wondering if I could just swap the two and have no performance change in terms of max WOT rpms. I know these two models are virtually identical but have no idea if the carbs have the same throat size and jetting. I plan on selling the 1982 model soon so I would hate to sell off a carb which I consider a better design. I'll prob swap the carbs and lake test it myself but I was curious to what others on here thought about this.
BTW, the 1992 model has good compression and spark and I have decarbed it recently as well. I'm sure it just needs some super tiny orifice cleaned but I do think the older design is superior and worth keeping over the plastic topped one.
