onepyramid
Thread starter- Joined
- Jun 20, 2014
- 35
First of all, I know this motor was rebuilt by a guy that is truly trusted and works wonders on outboards. After seven years in the basement, this motor fired on the second pull.
Now, having said that...with the motor cover off, it idles fine, it revs fine, reaches WOT fine, comes back down and will purr at idle. It will do this all day long, UNTIL I try to put the motor cover on....then it bogs down, as if it is being choked to death. If I do this while it is at idle, it dies. If done at half throttle, it dogs down by several hundred rpm and runs rough as a cob...and then eventually sputters and dies.
I thought it might be air starvation, but I cannot see any way that can be true. Nothing on the inside of the cover is blocking the throat of the carb. I can put my hand nearly all the way over the throat of the carb (with the cover off) and get no similar results...plus there would have to be enough air inside this cover to feed that small carb for quite awhile....and these bogging down results are immediate.
I can see no wires, or anything else for that matter, that are anywhere close to where the cover sits. Everything in the electrical circuit was new...plugs, points, plug wires, etc.
I am flummoxed. Any ideas???
