jonny rotten
Thread starter- Joined
- Jan 8, 2012
- 380
I just put my boat on new trailer and can lift the tongue with one finger. I have a few ideas and could use some advise.
A few measurements:
From axle to back of boat as it sits I have 6 ft
From the axle to the rear roller is 16"
From the back of the trailer to the back of boat is 21" as it sits.
(#1) I was thinking of drilling new holes in the bar the rollers are mounted to and sliding it forward so I could bring the boat further forward. The problem with that
would be right now the bar is centered and shifting it forward would put a lot of stress on the front side of the bar as it would be way away from the mounting bolts.
(#2) Leaving the bar as is and drilling holes on the top of the bar and moving just the roller setup towards over the axle. Which would still leave all the weight over and in front of the bracket...possible stress on the bar like in (#1)
(#3)Eliminating the bar altogether and mount the rollers to the bar bracket somehow. But that would eliminate the front rollers. Would that put stress on the hull with less rollers? Is this a standard setup and is there brackets I can get that are designed for this setup?
Its a Mercruiser 4.3. Any idea how far I'll need to move everything forward. All I have to work with is 16". Being I can lift the tongue with one finger and the back of the boat is 6 ft behind the axle will I need all of that 16".
The back cross member swivels to ride under the hull. If I remove/shorten the back half of the bar will the hull hit the cross member?
Moving the axle back seems not doable. The guide for the leaf spring is welded to the frame
Have room to move the winch post forward
ANY ideas are welcome....Thanks
A few measurements:
