Glu-vit is the shiz-nit
outonbizniz
I have a 1967 glastron that was left in the water for many years by the previous owner causing the gelcoat to craze badly. In rebuilding it I sanding down the hull to remove the ridges that form on either side of the crazing. <br /><br />I just tried glu-vit to coat the hull. It went on like honey and took 2 days to dry. After ALOT more sanding the glu-vit has filled and sealed the crazed areas so now they are completely fair. Just amazing stuff.<br /><br />now to prime & paint (FINALLY).
bubbakat
Re: Glu-vit is the shiz-nit
good deal todd you are on your way Go for it.
G DANE
I am on the other side of the pond - what is glu.vit ???
BigD
Todd<br /> Yeah, that is some good stuff. I just finished using it to seal my floor, I added some white pigment so I could see it easier when applying it.<br />Dennis
Fergulus
That stuff sounds perfect for what I need, but where can i buy it?
SeaMasterZ@aol.com
if its like honey, would it be best to spread it on with a bondo paddle? seems to me that crazing would be like grouting, lol, fill the cracks and away you go
outonbizniz
I used a brush. Hence Brush marks...hence alot of sanding.
