amacher1977
Thread starter- Joined
- May 18, 2016
- 14
Does anyone have a pdf of a profile 2000 two speed parts list? Trying to get parts for my trailer. Tags are all faded off to be able to identify the needed id numbers.
I would love to get the vin and jump on the website. Unfortunately they are both wiped out do to age. I am looking for the lock and gears. I will post some pictures of it
Shorelander has an instruction website for finding your serial number if you can't find it.
https://www.shorelandr(dot)com/parts/
Also, you should have a title or registration on the trailer that will give you the serial number of the trailer, which will begin with 1MD
If not, they show you where to look or take pictures of the trailer with a few measurements you can send them and they can identify the trailer for you.
By the way, the winch on that trailer should be a Dutton-Lainson hand winch and you should be able to buy parts from them as well.
Also, we had a thread about this very trailer and winch combo last Oct. Might read through it to get some information on it and how to fix it.
https://forums.iboats.com/forum/gene...0-winch-repair
Also with about 5 minutes of searching, I found the parts breakdown
http://www.bigriversltd.com/files/62...WINCH_ASSY.pdf
So, you are welcome.
The parts pdf is for a single speed system. The parts I need are for the second speed gears.
Q. My winch is not operating properly or a part has failed. I would like to get it back into service as quickly as possible. What can I do short of sending it to you for repair?
A. We first recommend checking out our troubleshooting manual which is loaded with detailed explanations of potential questions and solutions. You may also find a solution in our help videos section.
If those resources do not provide a solution to your winch issue, we are more than happy to assist you. Just give us a call at 1-800-569-6577 between 8 AM and 5 PM Central Time, Monday through Friday.
No VIN?
If you are unable to locate your VIN number, don't worry. We just need photos from the side, rear, and winch post along with the some measurements e-mailed to shorelandr@midwestindustries.com. For more information watch the "No Model Number, No Worries” video.
Just like I said!
:facepalm:
Wow, you guys are so fantastic. First I high jack a thread now I am obtuse. I am just guessing you guys don't talk to one person very long. I do appreciate the help, but for your people skills they suck. By the way no they are not the same gears. It uses the same housing. So get your fact straight before you call some one slow.if you look at the pictures I posted you can see that or was that to redundant for your liking. I was just checking to see if someone already had a pdf of the winch system. Don't worry I am very proficient on finding parts. Been doing it for 25 years now. You will not need to lift a finger to type and get them sore I got it from here.
