FIGMO
- Joined
- Jun 18, 2017
- 321
I have been making some progress on the deck boards. Almost ready to rivet them in place. Until I post those pictures, I have earlier pictures I took of the transom area and SW that I forgot to post. So here they are:
The transom is fully install and ready to go. The Z brace and knee brace both worked out well, nice tight fit!
Back transom is secured and you can see the brass drain holes for the SW.
Dry fitting the SW in place.
Nice tight fit and the SW lines up nicely with the drain holes.
Better shot.
Starting to fit the deck boards, and marking a line for the aluminum stringers so I can drill the holes for the rivets.
This is the board on the back of the transom. There is a minor gap there and I was wondering if I should just leave it alone or seal it?
Happy with the corners on the SW. Should be easy to seal it with 5200 when the time comes to do that.
Same for the seal along the transom, it all looks like it will fit back in place nicely.
Next will be the deck board pictures with the wooden stringers I marked out including the supports for the pedestal seat mounts.
Better shot.
