Hi all, new to the forum, new to this boat...
2002 15ft sylvan aluminum side console with a same year 25hp mercury 2 stroke 2 cylinder.
Got the boat this spring, went through it all pretty well, new batteries etc, but the motor wouldn't fire.
Rebuilt the carb and it started up with the muffs on it, took it out to the lake and it fires right up, but isn't idling great (have to give it a little gas) but am pretty sure the low speed idle is a bit lean.
I've never gotten this boat to go faster than 14 mph (indicated by the depth finder), gonna try the portable gps next time I go out. That was just me and a fuel tank, but the boat has 3 chairs and decks, 2 batteries, etc.
To make sure the motor is running to spec I installed a tach, and am reading 5000 rpm at WOT.
My question seems to be is it capable of moving faster? Seems to be from what I read it should go at least 20-25, the max rating is 40hp.
Motor seems to be kind of "wimpy" but is running smooth, both plugs were changed and when I checked them, they were both light brown and seem to be firing well.
Is there a high speed mixture setting for this carb? Where is it?
Thanks for any help!
MT
MT
