1lastweekend
- Joined
- Nov 7, 2015
- 52
Considering purchasing a Johnson 4.5HP, saw it run today and it seemed to run fine...The question is do I have the right year of the motor? The model # is J5RCSS, which should mean Johnson 5hp, rope start, and CS equals model year 1980 I believe. The designation for shaft length is a blank for 15" (which this motor is). Does anyone know what the last "S" stands for in the model #? I thought it was for a sailing designation but that doesn't seem right...
Also when I ran it in a test tank, there appeared to be no pee-hole or water discharge tube other than the spray of water coming out of the exhaust on the upper portion of the leg- is this normal for a 1980 4.5HP? I looked everywhere around, under and inside the lower cowling for any type of rubber discharge hose and found absolutely nothing...Want to make sure I am not missing anything if I decide to buy this motor...Thanks
