San_Diego_SeaRay
Thread starter- Joined
- Nov 9, 2014
- 346
I have a ~1993 Gen V Bravo 7.4 engine I'm working on. I'd like to make sure that the Temperature Alarm system is working properly. I know that the Oil Alarm works off of a normally on circuit, so that when you put the key in the ignition the oil alarm circuit is "ON" and so you hear the buzzing right before starting the engine. And then you turn the engine on and the oil pressure increases, the switch turns to an OFF mode, and the buzzer stops buzzing. So it's easy to tell that that circuit is working.
However, the Temp Alarm Switch works off of a normally off circuit. So that when you turn the ignition switch on, the Temp Alarm circuit is off. It's only if you reach a specified temperature (180 degrees?) does the temp switch ground out and the circuit is completed and the buzzer sounds. So my question is how can I test this circuit so that I know it will reliably trigger if needed?
