Paulywog0667
Thread starter- Joined
- Aug 5, 2017
- 139
Does anyone have experience with the stranded fillers? The product says waterproof. I found a couple small screw holes from who knows, but the boat motor and trailer where $500.00. I plan on sanding the entire boat and patching any small gauges or holes. Then recoating everything with a colored gelcoat. I still need to sand it better, but is a sanding, denatured alcohol scrub and work the stuff in the basic concept? Any recommendations on a product and where to get for priming and finish coat after all the sanding and patching? Or should I grind off the patch I used and use something else? Under the waterline patches, but will probably use the same product for above the water line.
