dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I just got a 1994 Maxum with 3.0L Mercruiser engine. It started at first with the starter fluid but after some carburetor cleaning it was starting well with a little bit of extra gas on the throttle. It was running a lit low on idle, and I'll rebuild a carburetor later to fix it. However, I tried to clean up the engine, it was oxidized in multiple places, and later changed the oil and the filter. After the oil change I tried to start it again and not even a click from the starter. I know it is unrelated to the oil change and most likely it is some connector that is not sitting tight. I checked the battery connectors, all good there, and tried to short cut the starter with the screwdriver. There was a spark when I shortened the terminals but no solenoid click. I will try tomorrow to first try to clean all the connectors and terminals on the starter and then try to crank it with the remote starter. Any other suggestions before I take out the starter to the starter and alternator shop for testing? Thx
