Evinrude 50 1991 replace VRO pump to old style pump
HasseEd
Can I use the vaccuum signal from pulse limiter to the old style fuelpump with 3 connections?
Thanks for any responses!
Faztbullet
Just get the 2 line with rear pulse port and mount where yellow pointer is ...remove the 1/4-20 bolt and plug off pulse limiter. 50.jpg
HasseEd
Already got a fuelpump with 3 lines that I think will work, so can I use the pulse limiter as vaccumline?
ahicks
To be honest, I don't know if there's a check valve in that fitting. If not, there's no reason it wouldn't serve well as a pulse port for your pump.
