JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,763
In trying to repair a broken starter recoil spring on my 1990 4 hp Johnson outboard (model J4RDHESR), I managed to misthread the bolt that holds the starter swing assembly (the part that swings up to engage the flywheel when pulling the rope) to the side of the engine block. As you can see in the pictures below, I not only messed up the threads, but the casting itself is cracked.
Is this something that can be repaired, short of replacing the entire block? Other than the starter spring problem, and now the problem I've created, the motor has been good and reliable.
Any thoughts?
Any thoughts?
