chevymaher
- Joined
- Mar 29, 2017
- 2,932
I have noticed the van runs better after it is waxed he may have something here.
Now is the time to upgrade to a newer stuff.
That's what I'm trying to find out what will fit what. Can't buy new. Have make sure gimbal housing assembly will fit my
gimbal housing mounting plate and will fit my older outdrive.
eBay is loaded with complete alpha drives or you could bring it out of the Stone Age and bolt on an off shore aluminum marine bracket. Some make the running surface longer and you would save some weight. Expensive but if you plan on keeping it 10 years and would like to keep it in the salt then a pair of outboards with a counterotation would bring a whole new Wow to that boat. It's only money and it sure is fun spending sombody else's on the web!
Yes. The more bonding area between old and new the better. Prep work on the old surface is important
The fiberglass store suggested that I wrap around corner and stern with three blending diminishing layers for strength and smoothing the finished look.
Thats one of the major drawbacks of removing the outer skin, not so much getting the strength back, but getting it cosmetically correct. You should wrap the inside 12-16 overlapping layers (at least 3)on each side, but the outside needs to be ground down to allow the new wraps to end up flush with the sides...at least 4-6 inches, then fair it the best you can, then try to match the gel color....not an easy feat cosmetically without making it look like a bandaid..
