Renderwurx
Thread starter- Joined
- Aug 14, 2017
- 189
Hi guys! Been lurking on here for some time and recently bought a (what I think is) really great project boat, a 1988 Blue Fin Sportsman 1900 with a Mercury 100. I have the boat completely gutted now and am going over design ideas in my head. The reason for this post is to understand what WAS in the boat for a livewell system. The PO never used it and only plugged the fitting when he "somewhat" restored the boat.
In the image, the red circle is a pump that is connected to a thru-transom port, with a long hose running up toward the front of the boat. it was not attached to anything, just an open hose. The green circle is a thru-hull port that is broken off and plugged from the outside.
My first thought was that fresh water was pumped in from the back of the boat thru the transom, and then overflowed to the front port. But the front port looks awful low to be an exit. Knowing there could have been multiple livewell/baitwells in use at once, or perhaps an owner replaced or added one... I wanted to see what you all think.
I believe the stock sport boat had a livewell in that area up front, and I intend on putting one in that area in my new floorplan. Any info or guidance would be appreciated.
