Re: Hovercraft; Neoteric Racer Rebuild
I have compleated one of the small holes and almost compleate with the second so this leaves me with only one major hole left, Of course it is the worst of the lot. I will post the pics soon.<br /><br />Today for something diffrent I tore into the engine. Keep in mind I am no mechanic but in the spirit of project I am going to attempt everything that is feasable with the ocasinal guidence from a local small engine mechanic, I owe him big already. <br /><br />Vacumed out sunflowers as per sbn advice, and checked compression 120 and 30 Ouch! Took the cylinder off to have a new piston installed and found two things. #1 was that the cylander will only need to be honed and a new ring set should correct the problem. #2 was the mouses emergency rations of sunflowers down below the piston with the crank shaft. Keep in mind that to test the compression I pulled on it several times, so his emergency rations have now been partially rendered into mush.<br /><br />Dale (my patient advisor) looked and determined that I should be ok with a thorough flushing and cleaning of the bearings. What a job and the consequences for not getting it cleaned well enoufgh is an estimated $400 job on the crankshaft. <br /><br />Final assesment for the day, I think i need a garage kitty that is also trained in the proper use of a sniper's rifle.<br /><br />Braindead, thanks for the offer but the skirt material is already on order. I got a feeling that is heavier stuff than i need anyways.
