Iceburgkennedy
Thread starter- Joined
- Jul 5, 2017
- 21
Where do I begin. I bought this boat from a private party in October of last year and it ran great. I immediately had it winterized and stored it until April 2017. I then remodeled the entire guts and paint to make it updated. Next I was told by a local to put in this crc brand hypoid oil(at the time I had zero knowledge that that is completely not right and have now found I need to use strictly type c.) So I filled it with the crc brand hypoid and was ready to go out for the first time after starting it in the driveway at least 5 times and it ran and idled great. I then was ready to hit the lake. I get there and unload the boat and after 10 tries it finally started and stayed running but when I would go to throttle forward it died every single time from what I am guessing the load and carbs need cleaned ? Anyways I finally revv'd it real high in neutral and then hit the forward button and finally it started going but when I did that I totally heard a grund or clunk in thr lower unit which did not sound good. Nonetheless at that time I had zero knowledge of my boat parts ECT. So off I went across the lake for about 3 yards and it ran good so decided to slow idle down and go slow but when I idled down it would just die. So it then took me like 15 tries to get it going and I figured at that point to head back closer to the dock. Well when I got closer and idled down to slow it died again. By this point I was beyond frustrated. So then I go to try starting it and the throttle box started smoking so I jump up and disconnect battery ect. and got the shameful toe and loaded my boat and went home. The next day I opened up the throttle box and sure enough the diode inside was fried. Long story kinds short, I have done lots and lots of troubleshooting and have since narrowed it down to that when I turn the key to the on position the green wire that goes from the inside of the engine that runs down to the shift solenoid to get hot and causes the diode inside the throttle box to get hot. Note, this does NOT get hit with both green and blue wires connect ed when I have the lower unit out. It only happens once I have it in and tighted up this is all so wierd to me.This is what I have done thus far and still have this issue......1. Replaced the throttle box diode with brand new one also cleaning up the throttle box from dirt ect. 2. Installed Newused lower unit solenoids I got online that I know work 3. Made an entire new harnesss with new wires that run from the solenoids thru the old solenoid housing plate up thru the motor. Also while down there I put in brand new impellar, gasket, housing cup, plate, exhaust gasket. I also have a new oil seal kit but have not installed them not sure if I have a leak but might . Could a seal leak cause the green wire to be grounding out ? Could the fact I put the wrong gear oil.in and ran it cause the problem ? Could not having any oil in in cause this problem ? PLEASE HELP !!! I am so frustrated and have now spend 3 months trying to get this boat running and Altho summer is over I hope to be ready for next year. I am sure I left stuff out but that's the just of it
