hello,
Ive been running this motor for 4 years without a hitch until now. I'll include other findings in case they are related
Whilst having a jiggle and poke around the powered I found that the flywheel can be lifted vertically, like excessive axial play on the crank, at least 2mm???
I have the carbs on the bench cause it would bog at wot but recovered if idled. Found collapsed check valve inside fuel pump(sucked into the cavity it seals)
from what I see on forums end play is measurable but certainly not visible ? No visible radial play but haven't measured yet...
Many thanks in advance,
Ross
Ross
