Sylva-Ranger
- Joined
- Jan 17, 2016
- 166
Suzuki 4 hp 2 strokes 1985 DT-4 00402-505089
Cold the engine run well, water pump pump normaly ............After few mins the water stop pumping water and overheat.
I change the impeller and gaskets, the pump,s cup is good.
All the seals and groomet from the pump to behind the powerhead are ok
I removed the powerhead to inspect and change the gasket,
the pipe beetwin the pump and the powerdhead is good to.
i also removed the head gasket to blow and clean the water passage and everyting seem to be good. In fact is not a realy cylinder head, is more a water passages cover gasket (like certain Merc).
is like when the engine reach a certain degres of temperature, the water stop circulate. when you stay the engine cool down and restart,the water begin to circulate again.
More you go faster, more the water sudently stop to circulate .
Any ideas ?
Any ideas ?
