JohnnyGuy
Thread starter- Joined
- Aug 24, 2017
- 196
Hi all,
I will be installing a water pump kit on my new-to-me 76 Johnson 15hp this weekend.
I've watched lots of videos and have done lots of reading.
So far I have come up with the following:
Water Pump Housing
3M 847
Water Pump Housing Plate
OMC Gasket Sealing Compound (I'll be using Permatex Form-A-Gastket No.3)
Lower End Unit
I work in construction and have a direct contact with an autoparts supplier. I for the life of me cannot find where to buy the 847 except for amazon and I don't want to spend $50+ dollars on a small tube of it.
I called my local OMC dealer and they don't have the 847 or "OMC Adhesive M".
I called another local marine repair shop (Mercury) and they said they use Loctite 518 for between the Housing and the Housing plate.
Does anyone have any opinions for an alternative?
Would Loctite 518 work? What about using the Gasket Sealing Compound instead.
One of the YouTube videos I watched, the guy used a very thin layer of RTV between the housing and the housing plate? With that being said I also watched many videos where the creator put nothing...
I'm not implying that either is correct.
I'm completely new to the wonderful world of Marine motors, any advice/direction would be greatly appreciated on how you would recommend I proceed.
Water Pump Housing
3M 847
Lower End Unit
