- Joined
- Oct 25, 2011
- 25,254
You need 2 - 2.25in thru the keyhole for a Mercruiser driveline, so there is a 3rd layer of plywood (on an aluminum boat, usually a layer of 1/2in) around the thru hole, on top of the assembled 1.5in transom plywood.
Not 100% familar w the I/O Holiday, so I'm not sure what 12in panel has to come off.....
Yep, pull the transom/rubrail corner caps, bend/cut the gunwales......
Pix are helpful, but shrink wrapped for winter hampers that....
