jbuote
Thread starter- Joined
- Aug 17, 2016
- 1,001
More of a curiosity question than anything else really, and some thoughts from the experts here would be great!!
No, I have no reason or cause to be checking my timing right now, but...
I was reading the section on checking the full advance timing in my Factory Service Manual.. (Got it from Ken Cook a while back now... )
It says to check timing:
The question though, lies in the "in neutral or in gear"...
I thought I've read on here multiple times, that it should be checked in gear, on lake etc.. for proper loading and not to cause possible runaway...
Neutral was not a good idea..
The take-away I get from the FSM, is that the backpressure from the water is really enough to prevent runaway in this instance..
Were there bulletins or updates to the FSM that would obviously not be included in the original manual?
Thanks for reading, and I look forward to your insights!
- Engine in test tank, or on boat in lake
- Set engine speed to a minimum 3500 RPM (Full Spark Advance) in neutral or in gear
- Spark advance should be 19? +/- 1?
