studioq
Thread starter- Joined
- Apr 11, 2014
- 201
So my question would be - shouldn't a healthy starter be able to do the same?
Seems mine has lost its torque and won't turn the motor any more. It will engage - but not make it through a full revolution - and just stops, hums and in general sounds unhappy. I've already hit it directly with current, bypassing the other components and gotten the same result. I pulled it apart and aside from being kind of dirty - the brushes are not worn away - or hardly worn at all. The twisted copper wiring of the armature is covered with a brown, hardened, plastic spooge of some sort - which may be normal.. Don't know.. First one I've ever looked at...
I'm just wondering if it's worth trying to rebuild... I'm sure pictures would help... But I'm not certain if a new brush set is all I'm going to need... I've read it needs to be cleaned and occasionally hit with an emery cloth here and there...
