JASinIL2006
- Joined
- Feb 10, 2012
- 5,762
I?ve been looking for a new oil extractot ever since my Moeller hand pump model fell apart after only a few uses. I recalled that someone here had used a shop vac so I thought I?d give it a try.
I bought a $28 three gallon wet-dry vac at WallyWorld and duct-taped section of garden hose (with a female connector on the end) to the vacuum cleaner hose. The two hoses together were long enough to reach from the threaded dipstick tube to the ground, where I sat the vac. (Not having done this before, I was a little bit worried about some of the oil possibly misting and getting exhausted out of the vacuum cleaner, so I did not want to vacuum cleaner inside the boat.) After running the engine to get the oil good and warm, I hooked up the hose and fired up the vac.
The contraption worked extremely well. After about 12-15 minutes, the hose started jumping a bit as the last bits of oil were extracted and some air was sucked into the dipstick tube.
I won?t be using the vac for anything else, but for less than $30, I can?t complain. The only thing I might change is to swap out the section of garden hose for a piece of similarly sized clear tubing, so there is some visual indicator of when all the oil has been extracted.
Just wanted the share with you all, in case anyone else wants to try it. I wish I could remember the name the iboats member who gave me the idea so I could say thanks.
