redneck joe
- Joined
- Mar 18, 2009
- 15,518
I found it a few years back and thought the window was the location thought at the time; just around the window but it traveled a bit on the sill plate / rim joist so wasn't sure. Tried patching all visible mortar spots, used a high dollar sealant on the front of the house which I thought fixed it but turns out just checked times when there had not been a bunch of rain.
Pulling the nasty carpet up to put in new hard floors this week and yep, all around the window. Nothing too visible up top on the surface but stains in the subfloor, HVAC vent has a nail all rusted to hell and the kicker was the carpet tack strip nails were rusted about 1 foot either side of the window. Sounding the OSB house skin tells me there is space between that and the brick so should not be a sweating issue. There was plenty of insulation. Moisture meter tells me close to ok on the house, just dripping wet rim joist down.
My thinking at this point, prior to cutting into the bricks which I will soon is either one or both of the following:
The slop from the mortar has jammed against the house not allowing flow to the outside of the foundation
the Tyvek (or similar product) was not installed properly/shorted/who knows.
Thoughts?
Thoughts?
