I completed a carb rebuild and was getting the motor to run in the barrel. Everything went well testing. I took the motor out and test it at the lake and I believe it overheated? At first I had issue starting the motor, but tweaking with the fuel mixture screw, I was able to get it running. I checked and water was coming out from tell tale, so the pump was working. I was cruising up and down near the dock after 30 minutes. Then I check the water to see if it's coming out from the tell tale and now no water was coming out. The engine did stall at this time. I try to ride back to dock, the engine stalled halfway. I couldn't get the motor to start again. I took it home and checked the impeller and it looks to be in good shape. Reinstall everything back and still cannot get the motor to start. What could be the problem?
